OK, maybe the TM32 is a different design than I was thinking.
I've done this before trying to lubricate the cable without getting into the carb. It's a small PITA to get it back together but it's doable.
Scottie J
I blew my load this morning carrying stuff up & down & cleaning up all the little messes I left in the garage from last week. So now I can start all over.
The last thing I did before I came up was scope out the throttle end of that new cable. Yes. I DO have to Dremel the ball. It will not fit as is through the hole it has to go through in the throttle grip housing. Once that's done then I'll have to futz it into the hole & width of the rotating
part of the throttle. That'll be much later this afternoon.
It's all part of the tangled web we weave when first we practice to modify what the factory & the Feds thought we wanted.
The wrist pin's in the freezer
