Author Topic: Build thread for my 865  (Read 26722 times)
Reply #195 on: April 01, 2021, 01:11:20 am
Very interested to hear all about the outcome!
Home of the Fireball 535 !
Gremlinsteve
Reply #196 on: April 01, 2021, 01:28:28 am
865cc on a stock tune runs but will have a major flat spot in the graph
I expect that to be cleaned up now and the future pulls will only increase the rwhp
Blazes Boylan
  • Brooklyn
Reply #197 on: April 01, 2021, 02:37:26 am
Plus 12 rwhp and zero tuning performed yet
The stock bike is about, what, 42 rwhp?  So that would put you at 54 before the tune.
Gremlinsteve
Reply #198 on: April 01, 2021, 02:55:53 am
Yep
Gremlinsteve
Reply #199 on: April 01, 2021, 03:37:49 am
I’m really hoping to reach 60 after the tune. Just don’t know if that will happen
Blazes Boylan
  • Brooklyn
Reply #200 on: April 01, 2021, 04:12:43 am
60hp seems completely realistic for all the work you’ve done.  Next winter I’m looking to install the S&S camshaft and high compression pistons, hopefully a much simpler process.  Naturally I’ll add a PowerTronic or Power Commander.  I’d definitely pay $350 for a dyno-tune.
Reply #201 on: April 01, 2021, 04:18:55 am
The flow should be enough with your head work for more power.
IMO, the S&S cam is a bit too advanced, and there is a little bit of room to retard it 3 degrees for a 110°ATDC intake lobe center. I don't know the cam fixing sysytem, but if it uses the common Woodruff Key, you could get an offset Woodruff Key for the amount you need to retard.
That should shift the torque peak up to a slightly higher rpm, which might give it the hp bump you seek.
I know some people say that 4-valve can run shorter durations because of valve area, but I looked at those S&S cam specs which I presume are @.050" lift, and I find them to be closing too early for higher rpm power, with the flow that you measured on your ports.
Not a lot of room to shift that cam, but there is a little bit of room to go to 110 on the intake.
If you don't reach your power goal, you might try it.
Jako
Reply #202 on: April 01, 2021, 08:24:06 am
Guy on 'RE 650 owners  Australia ' facebook page   claimed    93 hp  at the wheel. 865cc custom cam ( not S&S)  larger throttle bodies,  extensive head work,  custom headers . 6 hrs dyno time. Tuned by the guys who recently set the speed record at lake Gairdner salt flats.
2020 Rav Red Interceptor (wife's bike) ,Interceptor 2019 bakers express ,  2021 Honda cb500X, 2021  euro4 Himalayan (wife's)
Haggisman2
  • 2018 Interceptor
Reply #203 on: April 01, 2021, 09:22:54 am
60hp for all that work!
Previously "Haggisman"
Blazes Boylan
  • Brooklyn
Reply #204 on: April 01, 2021, 12:10:57 pm
If Gremlinsteve wants higher numbers he could always use a different dyno.  Maybe you folks in the Southern Hemisphere get better performance because everything is upside down.
Reply #205 on: April 01, 2021, 12:29:37 pm
So, I read just now that the S&S cam has adjustability.. That should make retarding easy. Maybe even try 5 or 6 degrees retard, if you seem to be getting results with the 3.
It will cost a little bit of low rpm power, but not much. Retarding the cam always gives more high rpm power with minimal reduction of some lower rpm power.
Gremlinsteve
Reply #206 on: April 01, 2021, 04:19:39 pm
I agree
It is in pretty much straight up right now
I’ll adjust it if needed
Gremlinsteve
Reply #207 on: April 02, 2021, 10:22:18 pm
Over 60 rwhp now with more to go
zimmemr
Reply #208 on: April 02, 2021, 10:45:28 pm
Nice job, you should be proud of yourself. That'd make for a pretty competitive entry level dirt track motor, one that'd certainly be capable of winning  at the pro-am level.
Reply #209 on: April 02, 2021, 10:54:31 pm
Looking good!
