Author Topic: Build thread for my 865  (Read 26737 times)
Gremlinsteve
Reply #165 on: March 17, 2021, 10:06:49 pm
To clarify that
You need several sets of hands to do this work along with a custom made ring compressor
Without those two things your going to have issues
All that’s left with this build is to adjust/set the valve lash and install the rocker cover and then exhaust
I’ll tidy up the wiring ect once I’m done
GravyDavy
Reply #166 on: March 18, 2021, 01:43:46 am
Next time, try Omega-shaped compressor bands and channellocks.(I don't know how to post the Greek letter here, but once you look it will be obvious.) Cheap, easy to make and easy to use. Just a strip of metal a bit wider than the ring spacing bent into most of a circle, with ears on the ends.
Gremlinsteve
Reply #167 on: March 18, 2021, 02:34:02 am
That’s what we did. Made a similar style band.  It was used twice. And it was basically destroyed getting it off
After the second use.  But it served its purpose
NVDucati
  • USA 2020 INT
Reply #168 on: March 18, 2021, 02:44:18 am
+1
These are from Summit Racing. The size of this particular set doesn't matter ... just illustrating GravyDavy" suggestion.
https://www.summitracing.com/parts/otc-4838
Member: AMA
Current Rides: '14 DL1000 ADV, '06 SV650N, '93 900CBRR, '74 Ducati 750GT, '14 Honda CB1000-R
Gremlinsteve
Reply #169 on: March 18, 2021, 03:07:13 am
Those look like what we made
GravyDavy
Reply #170 on: March 18, 2021, 11:39:19 am
Yep, that's the idea.  They can often be made narrower depending on the spacing of the ring grooves, which can help when space is tight.
Gremlinsteve
Reply #171 on: March 18, 2021, 07:10:17 pm
Initial fire went well
No oil leaks and it’s throttle responce is awesome
zimmemr
Reply #172 on: March 18, 2021, 07:16:06 pm
Way to go man, can't wait for the ride report.
Gremlinsteve
Reply #173 on: March 18, 2021, 07:24:24 pm
I have video but can’t post
GravyDavy
Reply #174 on: March 18, 2021, 07:44:27 pm
Nobody likes a tease, ya know!
Gremlinsteve
Reply #175 on: March 18, 2021, 07:46:22 pm
Can some one post it?   I can’t
I can text it
Hoiho
  • Dead horse beater
  • NZ - 2020 GT 650
Reply #176 on: March 18, 2021, 08:06:11 pm
Lots of ways - upload it to Youtube or if you share it via Dropbox (send me the link via PM), or I could upload it..
Gremlinsteve
Reply #177 on: March 19, 2021, 12:41:13 am
Test ride is tomorrow
Got no clutch right now.  So I need to determine what I did wrong
GravyDavy
Reply #178 on: March 19, 2021, 03:51:36 pm
Slipping or not releasing?  Did you soak the friction plates in oil overnight first?
Gremlinsteve
Reply #179 on: March 19, 2021, 04:37:59 pm
Nah. I installed the cover and the shaft rotated on me enough that it didn’t engage the clutch
All fixed now
