Boylan, have you looked at the dyno results Revelry has posted going that route? They have separate dyno charts for stock; air flow, cam and piston; and air flow, cam, piston and Powertronic on their second tuner video. Without the Powertronic, torque wavers considerably.
I've been comparing a fuel tuned version against stock, staring, rev matching for power output and I don't think I can justify $3k for what amounts to 4 or 5 hp and 3 or 4 ft/lb gains in everything below 5,500 rpm. I love that torque carries higher further and that peak hp is a good +9 over stock, but a lot of that power and pull sits at rpm that equates to significantly illegal speeds.
I haven't decided anything for certain. Installing the cam and pistons yourself will save big money. I'm not sure I'm ready for that now, but like you, maybe next winter.
