Hi all!
I'm brand new here as well to RE and the Himalayan.
I picked up a 2022 Himalayan a couple weeks ago. Its still winter here in North Dakota so I haven't been able to ride it more than around a snow free parking lot a bit lol.
I've come across one issue.
Mine doesn't have the compass, but it has the tripper. The gear position indicator is where the compass used to be instead of in the lcd display in the speedo. In the speedo there is nothing where the gear indicator usta be on these.
Problem- it shows neutral with an 'N' as you'd expect and the gears show up as 'G1', 'G2', etc..., except for 3rd gear. Third displays as 'G-'.
I have noticed thru playing around with it that if you hit a false neutral between gears it will show 'G-' as well.
Anyone else run into this? Any thoughts? Seems as tho 2022 RE shop manuals are unobtainium so no help there...
I've only got about 8 miles on it, lol, and probably one of those on the center stand playing around with it (7 deg F today).
Btw... I have a couple Japenese street bikes- these Royal Enfield bikes are wierd lol. That engine is enormous for a 411cc lol. I wanted something different (and Im cheap), there just aren't any RE's around here. Had to get this one from 200 miles away.
Anyways, any help on this or any advise on Royal Enfield in general or the Himalayan would be greatly appreciated.
