Author Topic: Sparks flying.  (Read 224 times)
Donat Santowiak
on: March 17, 2023, 08:04:28 am
Need some guidance in resolving an electric issue. Battery been on trickle charger for years 24/7. Dynojet installed.
Symptoms:
Bike started in garage. Turned off.
Wheeled outside no go. No fuel pump whine.
Dials winding irradically.
Tested battery 12.9 volts. But zero cranking amps
Removed battery terminals noticed slight casing melt at terminal areas
Installed new battery
When attaching terminals sparks fly everywhere.
Help!
From Victoria Australia
Honda cbr 600rr Repsol Edition
Moto Guzzi V7
Excelsior Universal 1947
Adrian II
Reply #1 on: March 17, 2023, 01:49:20 pm
If all the electrics are turned off there's a short circuit somewhere. Could be the reg/recifier is failing, which might account for the damage to the old battery.
A.
Donat Santowiak
Reply #2 on: March 17, 2023, 08:17:12 pm
Thank you.. looks like a job for an auto electrician.
Moto Guzzi V7
gizzo
  • Ding a ding dang my dangalong linglong
Reply #3 on: March 17, 2023, 09:08:50 pm
You could beging by disconnecting components one at a time and see if you can pin down which component is causing the problem. But agree, if you have a motorbike electrician available, it's a good job to farm out.
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
GSX250E
Donat Santowiak
Reply #4 on: March 18, 2023, 02:04:05 am
I have discovered what an idiot I am. 73 years old and getting worse.
The problem was caused by me attaching the rectifier earth wire to the battery positive terminal! Instead of the bracket bolt holding the battery in place..
Now the fuel pump runs, engine turns over but not running. All fuses OK.
I'll try the diagnostic test as outlined in the manual. Knowing my luck probably stuffed the lot.
Take photos next time.
Moto Guzzi V7
gizzo
Reply #5 on: March 18, 2023, 04:46:29 am
Oh no! Bad luck, chalk it up to experience. Maybe it's bricked the ecu?
Continental GT
Pantah
DR250
DRZ400SM
GSX250E
Donat Santowiak
Reply #6 on: March 19, 2023, 01:33:08 am
At the risk of labouring this topic before the bike goes to an autoelec.
Latest observations
Indicators work, kill switch OK, high beam flesh OK.
Diagnostic via earth cable does not flesh codes just stays on. Diagnostic light goes out when cranking, then comes back on.
Crank engine, fuel pump runs..
Battery Light stays on when cranking
Moto Guzzi V7
gizzo
Reply #7 on: March 19, 2023, 02:37:42 am
Check for a signal at the ignition pickup. Hopefully it's something easy like you didn't plug it in properly when you replaced the loom. Good luck.
Continental GT
Pantah
DR250
DRZ400SM
GSX250E
Donat Santowiak
Reply #8 on: March 19, 2023, 08:05:33 pm
Thank you.
Moto Guzzi V7
