MUCH better, thanks! Since I see the chain to the left, I am assuming this picture is taken from in front of the rear wheel and on the left side of the bike.
While it IS in a bad location as far as exposure to the elements goes, it appears to be shrouded inside that U shaped metal plate from below and covered from rear wheel spray, for the most part, by the large heat sink.
Hard to see where the wiring connection is, but if I'm seeing it off to the left of the VRR, it appears well protected right up to the VRR as well.
I'd say just go in there every once in a while, if the bike was out in wet weather often, or ridden on dirt roads and give the heat sink a bit of a scrub to keep it clean. A bit of dirt on that size a heat sink should be of no concern.
