Author Topic: New super meteor light controls  (Read 5501 times)
55CM1
  • Barcelona
on: March 16, 2023, 12:56:26 pm
Always giving it his head, this morning I asked for a budget to change the ignition switches and lights for those of the Super Meteor, in principle you should not have any problems changing them I'll tell you, they are super handsome chrome
BMW 100 rs - K75 Metropolitan - Honda Pan European 1100 - Yamaha 250 sr - Scooters Vespa 150 - Vespa 200 - Aprilia Leonardo 150 -Honda @ 150 -  Yamaha T Max 500 -
JessHerbst
Reply #1 on: March 16, 2023, 03:39:39 pm
This will not be plug & play.
 The SM650 controls have a hazard flasher on the right switch. The GT & Interceptor have all the indicator wires running only to left switch.
 I replaced my left switch for one that has a hazard flasher, and my right switch for one with Headlights on/off switch.
 To accomplish this I had to make an adapter. I used four connector blocks that plugged into the factory connectors.
 Basically the switches kept their plugs as did the bike, my adapter had male & female connectors for both sides so it plugs in-line between the switch plug and the bikes harness.
  I had to route power to the headlight which runs to the left switch to the right switch and back.
 For the SM650 switch you will need to do the same if you want the hazard switch to work.
 You will need to run a connection from the right hand hazard switch to the indicator wires on the left switch.
 Its not hard, but it helps if you have some experience with wiring and crimping connectors,
« Last Edit: March 16, 2023, 03:42:56 pm by JessHerbst »
2022 Rocker Red Continental GT650
Ton1959
Reply #2 on: March 16, 2023, 07:48:14 pm
The new Interceptor has the new switchgear too. It looks though that this might be the same as that from the Super Meteor.
« Last Edit: March 16, 2023, 07:53:59 pm by Ton1959 »
Tuh
Reply #3 on: March 17, 2023, 07:11:40 am
True, i sat on one at the dutch "motorbeurs" and i must say they felt much more comfortable. Im not really sold about the looks though.
I wonder if the cables are different then.
ridermak
Reply #4 on: March 17, 2023, 08:16:42 am
I'm in same boat currently. I've got plug n play kind of adapter to fit meteror switches in Interceptor, but not installed them yet.
Waiting for confirmation from service center if new interceptor's switchgear is direct fit. Will update you once I get more information.
Ride to Live, Live to Ride
JessHerbst
Reply #5 on: March 18, 2023, 07:41:17 pm
Uncle Stew says the Super Meteor 650 powers up the daytime running lights with the key switch but the headlights do not get power until the engine is running.
 The GT & Interceptor do not have any circuitry to support this feature.
 I do not think it is necessary as the stock headlight on the older 650s is not LED and this draws way more current and it is powered at key switch on.
Ton1959
Reply #6 on: March 18, 2023, 08:41:25 pm
My headlights only come on when the engine is running. They dont come on when I switch the ignition on.
JessHerbst
Reply #7 on: March 18, 2023, 10:22:24 pm
Well then I may be wrong. I thought that my headlight came on with the key. I swapped it out pretty soon after getting the bike with one that allows me to manually control the headlight separately from the DRL. So i could have easily missed that.
JessHerbst
Reply #8 on: March 18, 2023, 10:31:23 pm
This has me curious, the wiring diagram shows the headlight power coming from the ignition switch directly to the high/low beam switch.
 There does not seem to be anything in that circuit that would ‘know’ the engine was running.
 For most of you out there that have stock switches, does you headlight only come on with the engine running!
 It is possible for the wiring diagram to be wrong…
YellowDuck
Reply #9 on: March 18, 2023, 10:46:57 pm
2021 INT same as US model.  My headlight comes on with the ignition switch.
Hoiho
  • Dead horse beater
  • NZ - 2020 GT 650
Reply #10 on: March 18, 2023, 11:29:41 pm
Yes
JessHerbst
Reply #11 on: March 18, 2023, 11:30:02 pm
What year?
JessHerbst
Reply #12 on: March 18, 2023, 11:31:19 pm
ReddingRider
Reply #13 on: March 19, 2023, 12:03:25 am
With my 2021 INTerceptor (build date  jan 2021) the headlight comes on with the key.
2016 F700GS
2021 INTerceptor 650
Polsius
Reply #14 on: March 19, 2023, 05:54:03 am
Good morning, according to my information, Euro4 and Euro5 models differ at this point.
With the Euro4, the headlight lights up when the ignition is switched on, with the Euro5 only when the engine is running.
Best regards
Polsius
Royal Enfield Interceptor 650 Bj. 2020
MZ ES 150 Bj. 1965
MZ SM 125 Bj. 2008
