Get the hub cleaned up, the wheel rebuilt and the inside of the brake drum skimmed, then have a brake specialist fit some oversize linings to the shoes and skim the linings to match the brake drum ID. Bed the new linings in carefully and that's probably as much front brake as you want for an Avon ribbed front tire/tyre, assuming you're staying with the original 17" rim size.
A.
