https://cscmotorcycles.com/buy-a-bike/electric-scooters/rx1e-electric-motorcycle/https://www.youtube.com/watch?v=g5llyzQsOGsCSC RX1E first ride: A budget 80 MPH electric motorcycle
CSC RX1E Specifications
Motor: Liquid-cooled permanent-magnet
Peak Horsepower: 24 hp (18kW)
Torque: 61.2 lb-ft (83Nm)
Battery: Lithium-ion 96-volt, 64Ah
Battery Capacity: 6.16 kWh
Charger: 110-volt
Input Current: 15A
Range: 112 miles based on New European Driving Cycle (NEDC)
Frame: Tubular steel
Rake & Trail: 27°, 74mm
Wheelbase: 55.5 inches (1400mm)
Front Suspension: 37mm inverted telescopic fork, 4.7 inches travel, adjustable for rebound damping
Rear Suspension: Monoshock, 4.3 inches travel, adjustable spring preload and rebound damping
Front Brake: Two-piston caliper, 265mm disc
Rear Brake: Single-piston caliper, 240mm disc
Wheels: 17-inch aluminum
Tires: 100/80-17 front; 120/80-17 rear
Length: 82.2 inches (2090mm)
Width: 34.0 inches (865mm)
Height: 47.4 inches (1205mm)
Seat Height: 30.9 inches (780mm)
Ground Clearance: 6.0 inches (150mm)
Curb Weight: 436.5 pounds (198kg); 469 lb with luggage and crash bars
Max Load: 331 lb (150kg)
Top Speed: 75+ mph
Colors: Candy blue metallic, Candy red metallic, Charcoal gray metallic
Price: $8,495 (plus $410 dealer prep, documentation, and road-testing fees)
Availability: Spring 2023
