There's also a spacer behind the final drive sprocket that's necessary for proper gearbox operation. I found my drive sprocket nut a bit loose and this spacer chewed up, that was causing the gears to index improperly as the main shaft wasn't indexing correctly. If this spacer's not "clean", toss it and fit another. H's has all these bits.
