The float bowl issue was that the pin for the float arm hinge was sticking out and actually bent over. Totally weird as I never touched it. I'm sure it came like that but I cant be absolutely positive. Anyway, I had a pin lying around and fixed it. Lucky I didnt break anything. So I've got the assemble/disassemble/assemble thing going pretty well now. I'm down to my last pilot jet so I'll be able to make a decision on that. Still messing around with main jets and waiting for a bunch to arrive in the mail.
The power increase is really good. At half throttle the bike just keeps going. It's great. It'll pull to 100kph in 3rd gear, then shits itself when I twist to full throttle but that'll come good when I find the right jet. Dont worry, I'm not going to ride around at 100kph in 3rd gear, I just wanted to see what it would do. BTW, I have a H's close ratio gear set fitted and still got the 18t drive sprocket hence the quoted figures. Soon as the hill appears, I'm back to normal.
Looks like a fine weekend coming up so hopefully those jets turn up so I can finish the job. Thanks for your helps.
