That's why I thought it would have been fitted to USA bikes, because of the stricter emissions laws some states have. This system is similar to the old pav air injection. It operates on a vacuum from the inlet to open a valve to allow air into the exhaust, but only on a closed throttle, I think. This is one of the many reasons why my enfield are euro3 by choice and not euro4.
Yes... that is how I understand how they work. Whether it effects mapping with an o2 sensor in the head pipe, I'm not sure ? It is quite possible that OC was gifted a California bike , and it still does not have a PAV system on it. I don't believe they ever did. A California bike would be OK for the rest of the States, because they go beyond the minimum Federal Standards. But he's racing it off road, so it wou matter much anyway.
If you buy a PC-V here in the States from any dealer.... except the old CMW. It will come with a " canned" map it , based off of a EURO or UK Black dot 8809-100174 ECU. I believe this is because Dynojet UK was the first to use a PC-V on these bikes. And when they Started offering them here in the States... even directly from Dynojet. They just contained the same canned Map.... same company, UK and US. The canned maps that I have seen that were made here in the States ARE a little different. Now, that could be because of a different program in the ECU Or different fuel used , or just how the guy tuned the bike ? But I would always assume that the ECU are different and tune accordingly .
I can tell you that the Euro black dot ECU "canned map" in the PC-V add's a lot MORE fuel , with a stock exhaust and stock or aftermarket air cleaner , then a US Canned map with an after market Silencer and a K&N air filter. So that it telling me , for less mods on the Euro ECU ... it requires a greater amount of fuel to reach a similar target Air fuel ratio. Then does the US version with more mods. That tell's me the Euro ECU is set up to run leaner then our version...
