So, as I go through this bike, I've noticed some electrical things that aren't making sense to me.
The bike does not have a key, so that's new to me.
There seems to be some sort of ground loop somewhere, as the battery drains after a couple days, when parked.
I say this because when started, the bike appears to be charging. After running for a while, with the bike shut down, the headlight and taillight will remain lit until I turn them off at the headlight.
A day or two later, they do not illuminate, and the battery reads nearly 0V.
The other odd thing is that the combo horn/light switch on the left handlebar doesn't seem to work properly. With the switch on Headlight in H, one position of the handlebar switch gives lighting, the other position does not. With the switch on the Headlight in L, it's the opposite on the handlebar switch...
Also, if anyone has a 1957 Trailblazer wiring diagram, it would be appreciated, as the wire colors in the wiring diagram from Hitchcocks for the 1955-1958 Indian Trailblazer do not match my bike.
If no other diagram is available, I can sort through it with a DMM, just hoping there's info available that I haven't found.
Whole new learning experience here. Sorry for so many questions.
