Author Topic: Confession  (Read 2066 times)
General_Apathy
Reply #15 on: August 29, 2024, 12:32:11 am
Well, waved goodbye to the GT650 as it literally has not moved since getting the 500.
For any given ride I’d rather take the ‘smaller’ bike and the GT just feels like work.
Zero regrets as I waved it off and already looking at Hitchcocks for 500 bits and pieces 🤣
Keef Sparrow
Reply #16 on: August 29, 2024, 10:11:52 pm
Oh! it vibrates worse than any bike I've ridden in the last sixty years.  My Guzzi V7s were dreadful when new but as the mileage increases they do get smoother. They say 10k is needed to bed them in.
The Enfield has just over 2k miles on the clock so I am hoping it needs an extended running in period. What do you think?
My (then) new 2020 Trials was noticeably smoother after 2K, but it didn't vibrate much even when brand new. These motors vary enormously - some are dogs and some are far smoother. Apparently it's to do with how well (or not) the individual crankshafts are hand assembled & balanced at the factory. Mine was hitting the rev limiter at 75 (indicated) MPH as the Trials is lower geared due it's supposed 'off road' leanings and at about 70+ MPH
 the mirrors would blur and rotate out of adjustment, although the vibration still didn't feel too bad. Now at 8K this doesn't happen, although fitting a new taller readr tyre has helped by raising the gearing adding about 5 MPH to the point at which mirrors just begin to blur slightly and also top speed as the rev limited now doesn't kick in. I have read many reports of new riders selling UCE 500s at only 500 miles or so because they couldn't hack the vibration - if they had only kept the bike another 500-1000 miles until they were fully run-in they would probably have noticed a big reduction in vibration.
Past: CB125-T2, T500, GT500, Speed Triple, 955i Daytona. Now: Royal Enfield Bullet Trials 500
Brockett
Reply #17 on: September 01, 2024, 09:24:17 am
Futher to my previous post here:
Things I have discovered
No tyre valve caps - caps replaces
Speedo cable guide missing from front mudguard -  bought replacement from Hitchcocks
Only one bolt holding the ABS bracket in place - bought bolt from Hitchcocks
Only one bolt holding the ABS pump to it's bracket - strange as th bolt cannot fall out with the ABS pump in place
Note - The ABS pump cannot be removed without disonecting brake lines and this is not an easy job to do.
Rear mudguard scratched and paint damage due to overlong bolts securing the seat. Suspect previous owner removed pillion seat and used the same bolts without adding spacers!
Perils of buying a bike on line  but it's all fixable.
Nothing travels faster than the speed of time.
Brockett
Reply #18 on: September 01, 2024, 09:27:20 am
I am looking for tyres but cannot find a Rear 110/80-18
I like AVONs
What do others do?
I might also consider having Alloy rims fitted and going for something slighty wider. Has anyone else done this?
Blackdog62
  • You don't have to be mad but it helps
Reply #19 on: September 04, 2024, 07:20:23 pm
Avon 120/80-18 is fitted to my standard rear rim but the 100/90-19 is still up front and it handles beautifully, glad your enjoying you new purchase👍🏻
axman88
  • Vintage Motorcycle Fan
Reply #20 on: September 04, 2024, 10:11:20 pm
I like AVONs
What do others do?
How about a 110/90-18?
Personally, I like a 3.50-18, and will be transitioning to 3.50-19 when I get my C5 back on the road, using an older Bullet wheel I got 2nd hand.  Other folks have reported using 4.00 wide, 100% profile tires.
Crabsapper
  • So many experts......
Reply #21 on: September 04, 2024, 11:05:02 pm
I also fitted a 120 as I couldn't find a 110 Avon in stock.
It fits the rim better IMO and works well.
Some markets had a 120 fitted anyway, and even the owners manual states that a 120 is the correct size rear tyre.
