Royal Enfield Motorcycles => Bullet with the UCE engine => Topic started by: Rich Mintz on February 09, 2013, 11:23:24 pm
I bent a footpeg and scraped the end of the footpeg rubber on my 2010 Bullet C5 (you can guess how) and had to replace it. I bought OEM parts from Hitchcocks and am trying to figure out how to push the damn rubber on. I believe both the mounting arm and the rubber are the correct parts. I can slide the rubber on partway, enough to make the bike rideable, but how do I get it on the rest of the way -- do I have to ream out the channel in the inside of the rubber with a screwdriver?
Rich, I feel your pain ! May I suggest that you use Ronsonal lighter fluid or alcohol and shove it on. Works well with handlebar grips also. If you ream them they'll vibrate off.
Get a mallet and tap, tap, tap.
Boil some water, turn off the heat and put the rubber in said water for a few minutes. The rubber should now be pliable enough to press on.
Samgar
I have had good luck getting footpeg covers on with KY gel & a heavy hammer. when it dries out it's not slippery anymore.
No comment
Dish soap and water and a big soft blow hammer. Real Easy.
................ big soft blow hammer......
California style ! :o just like that across the chest ignition tester !!! ;D ;D ;D
I saw him use his helmet tester. Very impressive !
