Author Topic: LARGE WINDSHIELD  (Read 5937 times)
agagliardi
on: March 23, 2020, 08:45:07 pm
Anyone install an aftermarket touring windshield?  I have only seen Givi 's largest windshield available. Anyone try it yet?
1988 Super Magna(Disabled), 2000 Harley Softail, 2004 Hayabusa, 2020 Royal Enfield Interceptor, 2004 Corvette, 2019 Indian scout
olhogrider
  • Classic 350 Desert Sand
  • Blue Ridge Mountains of NC
Reply #1 on: March 23, 2020, 10:01:11 pm
I'm thinking of making or modifying a set of mounts for my Madstad windshield. I have it on my Speedmaster and it is the best windshield I have ever had. It adjust for tilt and vertically. I have the optional lowers. The whole thing is quick disconnect without needing tools. Unfortunately they are not universal. Each set of mounts is specific to each model of bike. If they made a set for the Interceptor I could just pop it off and swap it.
jimku
  • Nampa, Idaho USA
Reply #2 on: March 23, 2020, 10:21:20 pm
How does this strike your sensibilities?
It is a Memphis Shades Classic Deuce.
The handlebar mounts are heavy duty stainless steel and it is rock solid.
https://memphisshades.com/collections/handlebar-mount-windshield/products/classic-deuce-universal-handlebar-mount-windshield
« Last Edit: March 23, 2020, 10:26:16 pm by jimku »
2019 Interceptor.
I hope my tubeless wheels make you cringe. 8) https://www.dropbox.com/s/zobmpjq2gqtvypj/RE%20TIRE%20AND%20WHEEL.JPG?dl=0
Sometimes you're the windshield, sometimes you're the bug.
https://youtu.be/GG5ghP8XLW8
agagliardi
Reply #3 on: March 26, 2020, 01:12:10 am
Not bad Jimco/Wiley Coyote. Looks good. Memphis shields are great.I Have used the same Memphis Fats on my Softail for over 15+ years. Thanks
Warwick
Reply #4 on: March 26, 2020, 08:00:15 am
Looks functional. Has the bike enough power to push that through the wind :)
2007 Bullet, 1999 Lightning, 2010 Honda VFR1200f, 2019 Interceptor, 2007 Kwaka GPX250R
jimku
  • Nampa, Idaho USA
Reply #5 on: March 26, 2020, 08:03:43 am
Do bears crap in the woods?  No harder for the bike than pushing my upper body through the wind.
« Last Edit: March 26, 2020, 07:03:44 pm by jimku »
2019 Interceptor.
Roshiba777
Reply #6 on: March 26, 2020, 11:57:16 am
Hi found this while searching the web there is a company based in India which manufacture windshield for royal Enfield and specially for interceptor and Himalayan have a look sharing image of the same
They have both transparent and smoked windshields
Royal Enfield CI 500 (2000)
Royal Enfield STD UCE 500 (2010)
Royal Enfield Classic 500 (2011)
Royal Enfield Classic Chrome 500 (2011)
Yamaha RD350 (1988)
Royal Enfield Interceptor 650 (2019)
agagliardi
Reply #7 on: March 27, 2020, 01:07:01 am
Thanks 777  . For me, when it comes to windshields, size matters, big or nothing . I think Givi has the  one with the most coverage
jimku
  • Nampa, Idaho USA
Reply #8 on: March 27, 2020, 01:29:05 am
Do you have a link to that Givi windshield you are so enamored of?
2019 Interceptor.
Ove
Reply #9 on: March 27, 2020, 06:41:27 am
If you click on the photo, the supplier address is right at the bottom.
I've found with that style of shield, you're much less likely to get the vibration head buffeting, especially if they have some rake adjustment (and they look less like you're on a Road King)
jimku
  • Nampa, Idaho USA
Reply #10 on: March 27, 2020, 08:05:48 am
I don't see any photo.  I see an icon that looks like a document with "LARGE WINDSHIELD" beside it, but when I click on it I get nothing.
2019 Interceptor.
agagliardi
Reply #11 on: March 27, 2020, 04:05:20 pm
Hello Jimco, Assuming you are located in the USA, Just go to Giviusa.com . SKU:A31  4 POINT $113 . Also need D45 universal 4 point mounting kit. I believe this one fits. I am going to contact tech support to make sure before ordering.
jimku
  • Nampa, Idaho USA
Reply #12 on: March 27, 2020, 04:29:38 pm
That would be this one?
http://giviusa.com/givi-products/windshields/universal-windshields/a31-universal-windshield-detail
If so, I don't see where it's any bigger than my Memphis Shades Classic Deuce.
Or th Memphis Shades Demon.
https://memphisshades.com/collections/handlebar-mount-windshield/products/demon-universal-handlebar-mount-windshield
Maybe a little more expensive than the Givi …. but you get what you pay for.
« Last Edit: March 27, 2020, 04:42:54 pm by jimku »
2019 Interceptor.
agagliardi
Reply #13 on: March 27, 2020, 07:10:17 pm
The Givi seems to have hand protection. I would like to compare the dimension of both. I generally only use the shield for winter and long distance rides(both of which are rapidly decreasing with "age"), so a few inches makes all the difference.
agagliardi
Reply #14 on: March 27, 2020, 07:14:24 pm
I also prefer 4 point attachment. I never had any luck with any 2 point handlebar attachment shields, They always eventually move in the  wind no matter how tight. I think they may be OK for 50 MPH
