Hi Everybody
I have a Smiths Chronometric Digital Speedometer, which I'm trying to figure out the best way to install on my 2004 Royal Enfield 500 ES with ES removed.
I have the Smiths instructions, but when I look at it, I wonder if there must be a better way for us Royal Enfield riders..The reason I say this is because the standard speedometer that came with the bike has a bunch of wires that comes from the speedometer to a block connector that connects to another block connector that is connected the main wiring loom. There must be a way of retaining the use of the block connector that connects into the wiring loom?
If anybody else has wired this Speedometer into a Iron Barrelled bullet, I'm all ears as to how you did it?
Here are the instructions and wiring diagrams from Smiths. I've also included the correct wiring diagram from Pete Snidals manual for a 2004 500cc Bullet ES.
