La May turned out great. Good to see all the VME guys again and checked out the Pacific Museum of Motorcycling display. I rode well. The trials master Dana did his best but really most of the sections were set to tight. I did the best I could, won my class and really enjoyed the event. After the event I pulled the top end apart and had a look see. The bike was making a weird clattering noise when hot that would go away soon after starting. The bore and piston looked perfect so I just removed carbon off the top of the piston and installed a new base gasket. I disassembled the cylinder head completely and found the the intake and exhaust castings were horrible, so with a rat tail file I removed all kinds off flashing and reshaped or ported the head. I lapped in the decompression valve and the intake and exhaust valves. I found nothing that would make a clatter so with new gaskets I just put it all back together. Maybe the noise is something loose in the muffler?
