Royal Enfield Motorcycles => Bullet with the UCE engine => Topic started by: TheFatMan on June 13, 2013, 02:33:31 pm
Title: Neutral indicator light
Post by: TheFatMan on June 13, 2013, 02:33:31 pm
My bike is a 2010 C5 Military.  I have had a great time with it so far.  Last night on returning from a ride, my neutral indicator light is out. I have had the headlamp holder thingy (what is that thing called?) apart to change the five inch headlamp to a tri bar seven incher,  so changing the bulb is no problem, if that is what it is. Is there a way to check it without tearing the thing apart?  I suspect it's just a burned out bulb, any other possibilities?
TFM
Title: Re: Neutral indicator light
Post by: keithr on June 13, 2013, 03:06:07 pm
I thought my neutral light had failed last week while I was out for a ride and I stopped at some traffic lights. However, it turned out I was actually in a false neutral between 2nd and 3rd gear.  So before you change bulbs it might be worth checking that you're in the right neutral!  :D
Post by: Bulletman on June 13, 2013, 03:15:24 pm
TFM
You will have to check by doing a visual, While you are checking the bulb out, now would be a good time to change lights to LED which will last forever and are visible even in direct sunlight.
Do a search on this forum and there are many topics on this.
Post by: shamelin on June 13, 2013, 03:33:59 pm
Option #1: Swap out your neutral bulb for one of the pilot light bulbs to check for the bulb function.
Option #2: Use a voltmeter to make sure the neutral bulb harness is getting juice.
As long as your swapping out bulbs, it's a good time to consider LED bulb upgrades.  Singh5g has several excellent YouTube videos on this, as well as other RE maintenance and upgrade projects.  I personally prefer the old style bulbs in my speedometer, but I've changed all the indicator lights to LED bulbs.  Before it was difficult to see the neutral light in the Texas midday sun.  With the LED bulbs, it's not an issue.
http://www.youtube.com/watch?v=hMCSEraYCxM (http://www.youtube.com/watch?v=hMCSEraYCxM)
Post by: TheFatMan on June 13, 2013, 04:15:00 pm
Thanks all
Will check on them LED option, sounds like a good swap
Post by: barenekd on June 13, 2013, 06:15:35 pm
Even better for that illusive turn indicator light!
Post by: Gypsyjon on June 13, 2013, 10:58:58 pm
You make the swap to LEDs and you will be able to them during the day. It cuts down on mileage with the turn signals flashing too! ;-)
Post by: Arizoni on June 14, 2013, 01:03:13 am
I seem to recall that just any old LED won't work for the turn signal indicator without some supporting hardware.
Because of the weird wiring used for that light, positive electricity is supplied to both of its wires.
Post by: Bulletman on June 14, 2013, 04:50:42 am
Thefatman,
Here is a good link to follow
http://www.enfieldmotorcycles.com/forum/index.php/topic,15211.0.html
Post by: D the D on June 14, 2013, 05:18:25 am
On Iron Barrels you can just plug in a BA9 LED, it's the flashers themselves that require and electronic flasher unit  (or load resistors for the OEM thermal flasher unit).  Use the electronic unit, load resistors defeats any power savings.
For newer models here's one of the threads where people sort it out and post their results.
http://www.enfieldmotorcycles.com/forum/index.php/topic,10412.0.html (http://www.enfieldmotorcycles.com/forum/index.php/topic,10412.0.html)
Post by: Joash on June 17, 2013, 03:24:39 pm
Hi folks, thanks for all the great info here. I just getting to know my 2013 C5, and am working on upgrading at least the neutral and possibly the indicator bulbs to LED. When I got to actually remove the bulb yesterday I notice that they are now using the wedge shaped bulbs, for at least the neutral and trafficator lights. So it seems the BA9 type LEDs will not simply plug in
would this be a better alternative?
http://www.superbrightleds.com/moreinfo/instrument-cluster-gauge/194-led-bulb-4-led-wedge-base/198/ (http://www.superbrightleds.com/moreinfo/instrument-cluster-gauge/194-led-bulb-4-led-wedge-base/198/)
Post by: D the D on June 17, 2013, 03:35:39 pm
Yep, should do it if you have the 9.2mm/0.2" base.  Be sure to get the color to match the lens, i.e. green for neutral, blue for high beam, yellow for turn indicator.  The 32 degree will brighter and make them visible in daylight.
Just for my own curiosity; Are your trafficators and tail light bulbs plug in too?
Post by: Joash on June 17, 2013, 04:06:50 pm
Thanks for the tip- I have not looked the tail lights yet, and the two pilot lights do not seem to be plug in.
I was actually a little relieved to see that there was not the 'rat's nest 'of wires behind the headlamp assembly as seems to often be the case. :) Things seems to be grouped together for the most part, and there were 2 small rubber flap-like pieces  protecting/covering the base of main 'arteries as they came in.
Post by: Arizoni on June 18, 2013, 12:51:01 am
Royal Enfield is constantly improving their bikes and the improved wiring harness's in the casquette is one of them.
Now, if they improve their starter solenoid and chain quality it would be a good thing. :)
Post by: barenekd on June 18, 2013, 12:59:38 am
You can change any bulb of the bike to LED just by swapping them out, except the Turn Signals. The indicator can be swapped.
Post by: Arizoni on June 18, 2013, 01:08:52 am
I'm pretty sure of what you just wrote but some people might mis-read it.
The Neutral indicator light can be swapped out with a LED without a problem.
The turn signal indicator light can be a problem unless the correct type of LED is installed.
For this turn signal indicator light it must be the kind that will work with the electrical polarity going either way. (+ can be connected to either light contact and it will still work).
 Most LED's will only work if the electrical polarity is only going one way. (if the + connection is hooked to the wrong connector the bulb will not light).
Post by: D the D on June 18, 2013, 03:04:45 am
Right Bare and Arizoni!
The Turn Signal Indicator light must be AC capable.  They're marked as AC/DC in the specs like this one:
http://www.superbrightleds.com/moreinfo/wedge-bulbs/921-led-bulb-6-led-mini-wedge-base/201/ (http://www.superbrightleds.com/moreinfo/wedge-bulbs/921-led-bulb-6-led-mini-wedge-base/201/)
Edit:  No, they don't operate on AC current, but being diodes the bulb must be wired to light either direction (as an AC light bulb or they will only allow current to flow one direction and will not work correctly in the turn indicator).
Post by: Joash on June 20, 2013, 01:31:52 am
Well, at least the Neutral wedge LED swap  works great - that blinding green glare is reassuring for Bullet novices like me with all of 55 miles on the bike.  :)
Post by: Bulletman on June 20, 2013, 02:20:07 am
Now Joash, that's more like it, I was that way too..the green is very helpful.
Post by: Joash on June 26, 2013, 03:38:08 pm
Update: the same green LED (WLED-G4-32) seems to be working great on the Turn signal arrows as well. Very helpful in bright sunlight. :)
I did get a green AC/DC wedge too (T5-G6), just in case.
