I'm still puzzled. My oil level (2019 model 500) is above the max, unless I've put it on the sidestand first. My dealer's mechanic said that's right, run it for a short while put it on the sidestand, so the oil collects and then onto the centre stand to read the level through the glass. Everything else I've read has said, as soon as you put it on the sidestand, you won't get a true reading! Although apparently over-filled on the no sidestand reading, there's no blow into the air filter chamber that I can see. Only 400 miles so maybe too early to tell?
Confused.
