My front caliper is loose internally. If I grasp it by the gold casting, I can twist it back and forth slightly. The mounting bolts are tight. I can see the screw ends of the bolts that hold both sides together, but dont see any screw heads to check the tightness. The rear is loose also, but not as much. I know there needs to be some clearance between the screw bodies and the castings to compensate for expansion of the castings but want to be sure it is correct. Perhaps the clearances were increased for the recall calipers to prevent binding. When I hold the front brake on and push down on the bars, I can hear clunking of the caliper moving around. Has anyone else experienced this? I have 500 miles on it, I have noticed it after about 200 miles.
