Tried rotating it one notch today but the linkage gets too close to the footpeg mount and hits it during upshifting. Went back to the stock position for now. This may or may not be an issue with other bikes. Might have to figure out a slightly longer and/or adjustable linkage similar to the 410 and 650 linkages to raise the pedal without repositioning it at the shaft.
Yes, I tried it today too and had the same result. Dang! It doesn't need much more clearance to do it either. I'm thinking of going to a metal shop with that offending piece of the linkage and getting one made to the same dimensions, but with a small U shaped bend in the rod right at that point where it contacts the footage mount.. Maybe a winter project.
Moving it up that one spline did make the toe shift quite doable.
Let me know if you come up with a better idea or easier solution. Cheers!
P.S. Where are you located, as I noted you have a Supernova Blue, but can't tell from your avatar if it has the windshield? Supposedly not available to the North American market, unless you get it from Hitchcocks, as I did for my Stellar Blue.
