On my 2002 350ES the PO used improper excessively thick shims on the idler gears, eating into the case aluminum, which I found when I tried to pull off the timing cover. Aluminum case shreds had locked into the lubrication annular groves, preventing the cover from sliding off the shafts. Using
VERY judicious tapping on the covers handy alloy ear and a stack of plastic wedges cut from a milk jug and a wooden handle to pry (again, judiciously...
) on the oil filter housing end, I was eventually able to kedge the cover off and start clean up.
New cover gaskets & a variety of shims are on order. There seems to be only one cover gasket available now, but at least two thicknesses of shim. So far what I've found by searching the Forum is to stack on some shims on a gear, screw the cover on and see if it drags more when you pull it thru with the kicker; if it does, pop off the cover & adjust, check again. Seems pretty arbitrary.
Has anyone tried "Plastigage" in this application? (
https://en.wikipedia.org/wiki/Plastigauge )
A second question is about the
idler bushes; stock are steel, H's offer bronze ones, but how bad do they need to be before they affect running? Is it just noise, or does it make the timing noticeably erratic? There obviously has to be interplay between these bushings & proper shimming.
Thanks for any wisdom/hints/examples - ACR -
