Author Topic: What did you do to your RE Continental GT today?  (Read 391275 times)
0 Members and 3 Guests are viewing this topic.
Taurim
Reply #1350 on: July 28, 2021, 09:53:24 pm
My previous AEW muffler did not include a baffle so it was probably a different model. It was very loud, little difference in noise level when I started the bike without it !
It was this model :
KC1961
Reply #1351 on: July 29, 2021, 07:25:25 pm
That looks very similar to mine. Mine has a 2" / 51mm perforated tube / baffle inside with sound deadening material wrapped around it. So your one doesn't have this? I can't imagine how loud that would be having heard mine.
Taurim
Reply #1352 on: July 29, 2021, 08:32:44 pm
I think it was the same with the 51mm perforated tube. But for me it's almost straight through. The perforated tube is (too) big in diameter, not long enough and the sound deadening material volume is low.
What I call a baffle is more something like the tube on the right :
But the AEW does not come with that or a way to install a baffle easily.
The new generic muffler I bought corrects a lot of problems of the AEW :
- inox, a lot lighter
- longer, bigger diameter, smaller inner tube
- provided with a removable baffle
KC1961
Reply #1353 on: July 30, 2021, 01:02:00 pm
I spent a while looking for a 51mm baffle that would be a straight-forward fit, screw onto the end of the perforated tube. I didn't find anything suitable which meant resorting to using silicone sealer to fit this:
Taurim
Reply #1354 on: July 31, 2021, 12:14:34 pm
I did not find a correct baffle at the time either but I found my current muffler with  a more common 44mm baffle diameter and 520mm long.
The problem was that there was no exhaust kickup included but that's another story  :)
KC1961
Reply #1355 on: July 31, 2021, 04:53:52 pm
Here's the quieter version of the AEW. I fitted 3 x M4 screws through the perforated tube to support the baffle as well as using silicone sealer. Although I'd like to have a neater / less bodgey type arrangement this will have to do until I'm able to come up with something better.
Taurim
Reply #1356 on: July 31, 2021, 05:11:31 pm
With some carbon deposit it will be perfect ;)
Adrian II
Reply #1357 on: July 31, 2021, 10:23:08 pm
Is that a Bantam in the background to that photo?
A.
KC1961
Reply #1358 on: August 01, 2021, 07:09:50 pm
A.
1968 D14/4 supreme
Adrian II
Reply #1359 on: August 01, 2021, 09:11:28 pm
I started all this nonsense on BSAs, but with a C15.
A.
KC1961
Reply #1360 on: August 02, 2021, 04:56:27 pm
My mate has a 1959 C15 and I've been on it a few times. Strange how your opinion varies depending on the circumstances. When I jump off a modern bike onto it, it feels like a pile of junk, but if I get on it after riding my Bantam it feels like a luxurious powerhouse!
Arschloch
  • ...all is lost
Reply #1361 on: August 08, 2021, 07:44:48 pm
This is what I've found in my broken crank while repairing it. :o
gizzo
  • purple people
Reply #1362 on: August 08, 2021, 10:47:00 pm
Nasty. Would it have kept running like that if you'd been less sympathetic? How many km to wear out like that, and what was the cause? I know you've mentioned it before but it's been a while. I hope you have time to document the repair. It's outside the scope of what most of us could do at home but it's interesting to see how it's done.
Cheers
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
gizzo
  • purple people
Reply #1363 on: August 09, 2021, 05:38:38 am
New suspension goodies from YSS
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
Arschloch
  • ...all is lost
Reply #1364 on: August 09, 2021, 06:21:33 am
Cheers
It did run maybe 3km in that condition, enogh to take me home atleast. The failiour occured almost exactly at 20.000km and the bike was tuned to 37.5rwhp since 8.000km. At 19.000km i've dropped in however an forged piston that got it to 38rwhp and sized at the same time as the big end bearing failed. Therefore the most likely root cause is the piston which is why i'm back to stock piston.
The repair is straight forward, what is needed is a hydraulic press, a lathe and something to knock it into shape so it runs true. I don't have a press but a friend has. The more annoying part is the truing however it went really smoothly to my surprise.
« Last Edit: August 09, 2021, 06:30:38 am by derottone »
