Here is the link to the BB Indian Bullet Ignition link ( KIT00064 ). Go there & download this PDF.
http://www.boyerbransden.com/pdf/KIT00064.pdf15) LINE UP THE CENTRE OF THE ROTOR MAGNETS (FIG 1.) WITH THE CENTRE LINE OF THE TWO STATOR
COILS.TAP THE ROTOR BACK INTO ITS TAPER AND TIGHTEN THE 6mm CAPSCREW.
RECHECK T.D.C.AND ALIGNMENT AND REPEAT IF WRONG.These instructions appear to index the BB unit at mechanical TDC.
I
BELIEVE the BB operates at TDC for starting, then advances
after the engine achieves 1500 RPM or so. This is a good thing for electric start Bullets. AdrianII, Ace, BulletWhisperer I'm certain all have real experienced-based info here. I'm a points dude, I like to see it work - less voodoo and good enough for 22 Indian ponies.
Did you resolve the mechanical mystery shrapnel issues, or just decide "broke is broke" and want to see it actually run?
