Royal Enfield Motorcycles => Bullet Iron Barrel => Topic started by: rtillery02 on January 09, 2016, 06:21:13 pm
I just keep tryin to get my 2002 iron barrel headlamp bright enough to see well, without suckin up more power than my alternator can keep up with. After installing an H4 bucket from our Host, installing a Sylvania Silverstar Ultra & getting stranded on the roadside for a while from low battery voltage, I do believe....I HAVE ARRIVED. It took a Cyclops a/c to d/c rectifier module($35.99) & an H4 6000K HB2 COB LED hdlmp kit from Paradise Lights($18.99). The bulb actually burns 2 of the 3 leds' on low & all 3 on high beam. I loaded an extra battery into my saddlebag & rode till after dark, 3-4 hrs w/ plenty of stops on the way & all is well & REAL good night light.
Interesting! Post up pics and/or links
Sounds like something I might be interested in, and probably a few others too
Will do, I said an H4 "bucket" was installed...but what I meant was an H4 "LENS" to accept the bulb(Z90485 for $49.50). I'll wait till dark for some hopefully accurate pics of just how bright this light really is. A 7inch lens may just throw even more light out there, but I'm partial to the style of the 5 3/4 inch.
also interested...
did you have problem fitting the "big bottom" led light in the casquette?
Ben
Keeper wires stretched over the bulb fan & right into their slots, no problem. I finally can attach some photos of the set up, but the light is so bright it's real tough to get a decent pic of just how much light it throws, it's AWESOME! I'll need to borrow a better camera to share just how much better it really is.
