Author Topic: Shock preload adjustment tool, cheap!  (Read 10789 times)
2bikebill
Reply #15 on: August 12, 2010, 08:26:34 am
Here's the toolkit from my 2010 G5 DL  (UK)  The big spanner doesn't fit in the toolroll so came separate, with the spare cables etc
« Last Edit: August 12, 2010, 08:30:20 am by WillW »
2009 Royal Enfield Electra (G5)
Reply #16 on: August 12, 2010, 02:32:55 pm
I didn't get the big spanner either.  I'm guessing that's the right size for the axle bolts and the large engine mounting bolts.  Oh well, all part of the charm of this bike :)
My Ducati had a spark plug wrench and a bad screwdriver, neither of which I ever used.  It did come in a really nice little nylon bag with the Ducati logo though.
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
Reply #17 on: August 12, 2010, 04:35:30 pm
ok so your's is a 2010, but a G5. Maybe its just G5's getting the suspension wrenches?
Reply #18 on: August 12, 2010, 05:36:23 pm
I'm a 2010 C5 US model.
Reply #19 on: August 12, 2010, 10:02:26 pm
I have a G5 Classic in US and I got exact same tool kit, except that I did not get a large spanner separately.
The kit has a small shock wrench (preload adjusting spanner) as shown in WillW's picture.  There were also cables and tube in a large cardboard box.
Most of the motorcycle dealers carry a $15 shock wrench by Motion Pro or another brand that will fit RE.
http://www.motorcycle-superstore.com/2/9/205/5006/ITEM/Motion-Pro-Shock-Wrench.aspx
« Last Edit: August 12, 2010, 10:25:55 pm by singhg5 »
Reply #20 on: August 12, 2010, 10:48:17 pm
I couldn't find that one in stock anywhere and the only references to sizes it fit was bigger than what I measured.  Hence my diversion to bicycle tools.
Reply #21 on: August 12, 2010, 10:58:13 pm
No shock spanner came in mine.  .............
What is a "Tommy Bar"?
Just a straight bar or rod that fits into the holes of a spark plug wrench, so that when you use it as a lever to turn the wrench the whole thing looks like a 'T'.
qgolden
Reply #22 on: August 12, 2010, 11:10:46 pm
Oh,
OK,  Thanks.  Back in the day  ;)  We called that a "Handle"    I jus' love these new fangled terms!   :D :D :D
Reply #23 on: August 12, 2010, 11:12:36 pm
Me too!  "Trafficator!"
« Last Edit: August 12, 2010, 11:48:09 pm by Ducati Scotty »
Reply #24 on: August 12, 2010, 11:37:41 pm
You guys finally got me curious enough to actually look at my tool kit, no preload spanner in mine either.
Reply #25 on: August 12, 2010, 11:46:46 pm
C5 riders are tough guys - they just twist the shock with their hand, just like opening a beer bottle. ;)
« Last Edit: August 13, 2010, 12:04:46 am by singhg5 »
Reply #26 on: August 14, 2010, 06:02:05 pm
BTW, the three point side of the wrench does not fit the shock.
Maturin
  • My Precious
Reply #27 on: August 15, 2010, 11:17:21 pm
Twisting the shock with your hand is for wimps - tough riders use their teeth  ;D
There are adjustable hook wrenches, I used them for BMW steering heads. This old thing works fine with the RE shocks.
2010 G5
Walter Röhrl
Reply #28 on: August 15, 2010, 11:34:16 pm
Twisting the shock with your hand is for wimps - tough riders use their teeth.  ;D
Heh, I'm looking at the dental bill for a new crown after using my teeth "improperly".   :o
Reply #29 on: August 16, 2010, 02:23:26 am
The ones I saw looked really nice and were pricey!
