Hello,
Since I have now already installed some additional consumers on my Himalayan, I need a relay for a switched plus.
I found out, that the obd connector (see picture 1) has a switched +12 volt signal that could be used to drive the relay. The brown wire (see picture 2) has 12 volts on it when the ignition is turned on.
Does anyone know what current can be applied to this line?
The relay draws about 300-400 mA.
In my case I would like to use it to control the relay, which then applies the battery voltage to my consumers.
I would already have a counter plug for it....
But I do not want to smoke any electronics....
The circuit diagram in the Himalayan manual is unfortunately of such a bad quality, that I can not identify anything....
Thanks for help.
Toni
