Well, I've kept up with all these almost 1,100 posts even though I'm a dinosaur with an AVL (and this goes for them, too ) and all I can think is there are just way too many, wires, circuits, connectors, plugs, switches, black boxes and arcane doo-dads on bikes being piled on more and more in the past 20 years.
The average person now has no chance of dealing with it and must rely on the "service" of "experts" in a secret "service area" where you are not even allowed to enter to talk over what is wrong.
It's just all out of control as far as I'm concerned. I built a bike totally from scratch in '99 - 2003 with 7 wires (I drew up my own wiring diagram over a winter and it started first thing (I was amazed!) and everything worked and it ran perfectly until 2016 when I gave it to my best friend (who was around for the whole build) and he's riding it still.
I'm not saying we shouldn't have electronic and electrical progress (you can't stop progress), but the average guy can't even keep a bike on the road nowadays and in a lot of cases is a total victim in the whole "service department" machine.
Just sayin'
I’m trying to use the mystic “Wiring Diagram”. It’s beyond sensible. At the very bottom, there’s fuse 4 and fuse 5. At the very top are more fuses. There is absolutely zero connection between the paper picture and the motorcycle.
I checked the fuses when I saw what I thought the fuse box. I had to figure out how to open the box!
I have no idea where the Green wire gets it’s positive charge from. The Green wire line runs between brake switches and some light switches.
The Green and RedWhite pair are connected to the rear brake light switch. They run into the tail light. At the rear brake switch, the RW reads hot at 12v. This is the opposite of what it should be, I think.
I have good tools. I have a VOM meter. I I have a Power Probe III. It gets connected to the battery, POS and Neg. When I touch any wire it will light pos or neg. At the touch of a button, it will send 12v of power to a wire or a device.
With all that, I don’t know how to fix this thing.
BTW, the instruments don’t have to run on wires, complicating the electronic pile. They use to be mechanical. They worked.
