Author Topic: Weired Handling  (Read 11997 times)
Subbu-500
  • I am like....no big deal!
on: November 07, 2018, 03:33:33 pm
Hi All,
So my 2014 B5 with roughly 28k miles on it has started to scare me every now and then with its weired handling. Everything seems fine until i feel a sudden pull from side to side as if the rear and front wheel have had a heated argument and want to go their separate ways  :o... it is nothing dramatic..its almost as if i am zig zaging in a controlled manner if you know what i mean. But i can feel certain sideways movement and have to make minor steering inputs to counter them. It happens at all speeds but is most noticeable when i accelerate to say 60+ kmph and close the throttle even on perfectly smooth roads.
Things done so far: Brand new rear tyre, Got the Front and Rear wheels alligned 4 times in the last 45 days, the service center guys casually inspected the rear section and concluded the swingarm and all related components were good, i got the rear wheel bearings replaced. None of the above have had any effect what so ever on the problem. Please help.
Subbu
2019 Interceptor
2014 B5(Carb)
Richard230
Reply #1 on: November 07, 2018, 05:00:30 pm
Could it be due to the new tires?  Maybe a defect or caused by the tread design?  Perhaps you could try different air pressures.  ???
Roger
Reply #2 on: November 07, 2018, 06:16:44 pm
There's a section of CA101 just south of King City that makes my bikes act squirrelly.  Have you noticed it happening on a certain section of road?
2017 Bullet
2007 Ural Patrol - the 'trol
Subbu-500
Reply #3 on: November 07, 2018, 06:33:06 pm
Sorry i should have clarified it. This issue existed even before the rear tyre was replaced, in fact i got the new tyre because i assumed that the old tyre was causing it.
No it happens on perfectly good roads too. :-\
Subbu
2019 Interceptor
2014 B5(Carb)
Roger
Reply #4 on: November 07, 2018, 06:38:25 pm
Have you checked the steering head bearings?
2017 Bullet
longstrokeclassic
Reply #5 on: November 07, 2018, 07:20:43 pm
Swinging arm spindle nut worked loose?
Never underestimate the value of improved combustion efficiency and reducing parasitic engine and rolling chassis losses.
Subbu-500
Reply #6 on: November 07, 2018, 07:23:15 pm
No I haven't checked anything in the front. I will have that looked into. But I am 99% confident that something else is the culprit because there is no movement felt at the handlebars at all.. All the action originates from some where underneath the seat. Like from the mid section of the motorcycle  :-\
Subbu
2019 Interceptor
2014 B5(Carb)
Subbu-500
Reply #7 on: November 07, 2018, 07:28:42 pm
Would that not cause the entire rear wheel assembly to move from side to side when tugged while on center stand? If it does, then that is not the case either as the rear wheel assembly is really solid with no side way movement
Subbu
2019 Interceptor
2014 B5(Carb)
GlennF
Reply #8 on: November 07, 2018, 10:12:32 pm
I would also look at rear brake in case its binding and check the shocks and the preload settings.
HUdson51
Reply #9 on: November 08, 2018, 03:28:09 am
Check the frame very carefully for any cracks around the welds. There have been instances of this happening. The quality of steel used on the frames is not the best.
mike_bike_kite
Reply #10 on: November 08, 2018, 07:54:15 am
It sounds to me like the swing arm bushings need replacing. I had a very similar experience on a different bike and this was the cause.
2018 C5 Pegasus + NC750X + Vespa GT + Vespa GTS
9fingers
  • From the New Hampshire part of New Jersey
Reply #11 on: November 08, 2018, 12:55:52 pm
My thought too.
Currently own:
2016 Classic Chrome Maroon
2020 Moto Guzzi V7III Special
V Strom 650 ABS Adventure
Beta Rev 3 270
Honda TLR200 custom
Honda TL 250 TMI custom frame
Honda TL 125
Yamaha TY350
Jako
Reply #12 on: November 08, 2018, 01:00:13 pm
Like portisheadric said check swing arm spindle nut is tight.  Sounds exactly how mine was behaving .
2020 Rav Red Interceptor (wife's bike) ,Interceptor 2019 bakers express ,  2021 Honda cb500X, 2021  euro4 Himalayan (wife's)
Subbu-500
Reply #13 on: November 08, 2018, 01:49:53 pm
Thanks everyone, i will get the swingarm spindle and bushings checked/replaced and report back then. Hopefully this is the fix.
Subbu
2019 Interceptor
2014 B5(Carb)
Jako
Reply #14 on: November 08, 2018, 09:11:17 pm
Check the spindle nut first , if this is loose it will feel like the bushes are worn , I ordered new bushes then discovered it was just the loose nut . The inner bush sleeve  4 needs to be clamped solid between the frame
