I had a great time! As always so much fun to hang out with fellow Enfield owners. Think today was the longest ride I've done with the rebuilt motor. It ran great and didn't miss a beat.
Thank you for all the kind words on my Bike, I think I might need another hobby as I spend way to much time cleaning my bike
Damon
Oh no you don't.
What you need is a Newby Belt Drive Primary and Dry Clutch, and an Ace Super Fireball Roller Rocker Head and TM34 carb!
Let's get those valves open! With your Hitchcock cams .380" intake lobe lift, the ratio on the roller rockers will give you .550" lift at the valve. You would be seeing probably 60 cfm flow increase at max flow. You'd need the Newby clutch to hold that power. You wouldn't believe the torque it would have.
Of course, that's if you get tired of cleaning, and want to just blow the dust off as you ride!
And yes, I'll add +1 to the comments that your bike looks great!
