Author Topic: Monoblock Carb  (Read 2047 times)
Link1473
on: June 01, 2023, 11:23:19 pm
Hi all.
My 1955 Bullet 350 is spitting back through the Carb. Any tips on what might be the problem.
Regards
Chris
Adrian II
Reply #1 on: June 02, 2023, 11:31:36 am
Often it's a sign of too weak a carb throttle slide, or if that's an all-original Amal carb the slide could be quite worn by now and might need a replacement.
The other thing is to check your ignition timing in case it's too far advanced, I assume the manual advance and retard on the magdyno is working OK?
Link1473
Reply #2 on: June 02, 2023, 01:42:11 pm
Thanks for reply.
Adv/Rtd is working fine. Ign timing is correct. What are the best size Jets for it. I  would think it is the original Carb.
Adrian II
Reply #3 on: June 03, 2023, 08:46:12 pm
This topic really needs to be posted in the vintage RE section as it's a technical query.
The workshop manual has the carburettor settings in Section F. If the paper copy is not available you can download an electronic one for the pre-'56 Bullets HERE:
https://accessories.hitchcocksmotorcycles.com/core/media/media.nl?id=238071&c=1062795&h=624548bb9264a362b106&_xt=.pdf
The manual shows a type 276 carb rather than a Monobloc, which could be a later addition if that's what your Bullet currently has.
