Author Topic: Alloy Frames  (Read 127 times)
AzCal Retred
  • Chennai Wrencher
on: November 26, 2021, 06:53:06 am
The "Word" from The Man!  :)
https://www.cycleworld.com/everything-youve-ever-wanted-to-know-about-aluminum/
https://www.cycleworld.com/story/blogs/ask-kevin/how-cast-aluminum-chassis-became-possible/
http://www.r-r-racing.com/HD%20frame%20page.htm
"Aluminum Hardtail Frames Starting at $1400"
Seems like with a UCE motor in one of these alloy frames, and with alloy rims, you could be looking at a 325 pound or so road burner. Losing 75-100 pounds is like gaining horsepower, plus the chiropractic bills go down. RRR Racing could likely whomp up one for maybe $2K-ish?
A trifecta of Bullets: a Red Deluxe 500, a Green Standard 500, and a Black ES 350.
Karl Childers
  • Ghost in the machine.
Reply #1 on: November 26, 2021, 03:18:20 pm
While familiar with alloy perimeter frames that's the first I've seen tube frames done up in it. Harley has never been too concerned with the weight of their motorcycles so an alloy frame is only going to pay so many dividends, I can definitely see the advantage for other sportier classic bikes.
AzCal Retred
  • Chennai Wrencher
Reply #2 on: November 26, 2021, 06:05:35 pm
The UCE engine should be "lighter per HP" than a Pre-Unit assembly, if engineering runs true to form. Either would be interesting in an alloy frame. Less Weight = more better!   ;D ;D ;D
