There WILL be a touring contingent, just to prove you can do it. 110 MPG, shaft drive, factory storage compartment for a cheap rain suit & a hoagie, what's not to like?
2022 HONDA NAVI
Price (MSRP) $1,807
Engine 109.2 cc, air-and-fan-cooled, overhead-cam, two-valve single
Transmission,
final drive CVT and automatic centrifugal dry clutch, belt
Claimed horsepower N/A
Claimed torque N/A
Frame Steel-tube
Front suspension 26.8 mm inverted fork; 3.9 inches of travel
Rear suspension Single shock; 2.8 inches of travel
Front brake Single mechanical 130 mm drum
Rear brake Single mechanical 130 mm drum
Rake, trail 27.5 degrees, 3.2 inches
Wheelbase 50.6 inches
Seat height 30.1 inches
Fuel capacity 0.9 gallons
Tires 90/90-12 front, 90/100-10 rear
Claimed weight 236 pounds
Available January 2022
Warranty 12 months
More info hondapowersports.com
https://economictimes.indiatimes.com/auto/honda-navi-8-things-you-need-to-know/slideshow/52828493.cms" Fuel and speed - The Navi has a fuel tank capacity of 3.8 litres and can average a fuel mileage of 60 km/l. It is also capable of a top speed of 81 km/h. " {81 KPH is nominally 50 MPH, so likely 40-45 sustained "cruise", given windless flat ground conditions}
Check out the hollow section 8 seconds in.
2018 Honda Navi Review!!
https://www.youtube.com/watch?v=aBw-sMk6IpI
