Axman88 @ #5: 6 speed gearbox? A 10,000 RPM redline? Maybe Qianjiang has a source for boron fiber con rods?
What a machine - the UCE that should have been. I wonder if it'll make it to India? There'll be tears in Madras if it does.
Probably you have to buy one in Hongkong, Macao or Hainan & ship it home in pieces. I'd have one if it came here.
It kinda looks like a "Big Boy" Meteor competitor. If it really has a 6-speed transmission, that's awesome. I haven't found a price yet. - ACR -
https://bikespeci.blogspot.com/2021/04/qjmotor-qj500-8a-price-photos-millage.htmlQJ500-8A - CLASSIC RETRO
500cc Single Cylinder Air-Cooled Engine(19.0kW/55000rpm, 40.0N·m/4000rpm)" Classic Retro Timeless Design- 90-degree Upright Engine, Round Headlight, Round Meter, Double Seat, and Vintage Fuel Tank.
Efficient Braking System: Front - Ø 300mm Disc with 2-Pot Caliper / Rear - Ø 240mm Disc with single pot Caliper.
Displacement ; 530CC
Fuel tank capacity ; 15.5L
TECHNICAL DATA
DIMENSIONS
L x W x H (mm) 2170 x 820 x 1120
Wheel Base (mm) 1440
Seat Height (mm) 800
Ground Clearance(mm) 155
Curb Weight(kg) 205
FRAME
Type Cradle/Steel
Front Suspension / Travel (mm) Telescopic 120
Rear Suspension / Travel ( mm) Unit Swing 60
Front Tyre / Type 100/90-19 Tubeless
Rear Tyre / Type 130/80-18 Tubeless
Front Brake (mm) Hydraulic Disk Ø 300
Rear Brake (mm) Hydraulic Disk Ø 240
Fuel Capacity (L) 15.5
ENGINE
Type 4-Stroke
Cooling System Air-Cooled
Cylinder Arrangement Single Cylinder
Valve Train SOHC 2V
Bore x Stroke (mm) 86.0 x 90.0
Displacement (cc) 530
Compression Ratio 8.5 : 1
Maximum Horsepower (kW/rpm) 19.0/ 5500
Maximum Torque (Nm/rpm) 40.0/ 4000
Fuel System EFI
Lubrication System Forced and Splash
DRIVE & ELECTRICAL
Clutch Manual,Multiplate Wet Cluch
Transmission Chain
Gear Shift Pattern
1-N-2-3-4-5-6Ignition System TCI
Starting System Electric
