Author Topic: Early Rev Limit in 1st gear?  (Read 3264 times)
gizzo
  • purple people
Reply #15 on: September 13, 2021, 08:43:57 am
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
NVDucati
  • USA 2020 INT
Reply #16 on: September 13, 2021, 12:54:31 pm
Life is simple. Apostrophes are not.
https://www.grammarbook.com/punctuation/apostro.asp
An example is good ol' rule number 10:
"Rule 10. Beware of false possessives, which often occur with nouns ending in s. Don’t add apostrophes to noun-derived adjectives ending in s. Close analysis is the best guide."
Member: AMA
Current Rides: '14 DL1000 ADV, '06 SV650N, '93 900CBRR, '74 Ducati 750GT, '14 Honda CB1000-R
Yinzer
  • Pittsburgh, Pa.
Reply #17 on: October 28, 2021, 11:51:52 am
In 1st gear the tacho hit about 6500rpm and there was a breif cut in the ignition
I find it quite annoying, that's why I never go above 6K on the center stand in 1st.
(I like to pop wheelies and that's the only way I can figure to get the 650s front wheel up  ;D)
2022 Interceptor MkIII (My bike)
1998 Iron Bullet 500 (Shared bike)
2023 Hunter 350 (Dad's bike)
dcolak
Reply #18 on: November 24, 2021, 06:18:29 pm
Rev limiter in 1st is lower than in other gears!
I was surprised as well, it was cutting before going into red, but only in 1st.
It's by design.
Triumph 800XC, Royal Enfield 650GT
whippers
Reply #19 on: November 24, 2021, 06:23:53 pm
It's by design.
Unless you know that for certain and can provide the source it’s far more likely the rev counter needle damping just means it doesn’t get to read to redline in first before the ignition cutout occurs.  It’s not a superbike there is no rational reason to vary the rev limiter by gear.
2021 Royal Enfield 650 Interceptor Baker Express
2007 Ducati Monster S4RS
The older I get the Faster I was
CPJS
Reply #20 on: November 24, 2021, 06:47:29 pm
Easy to find out, accelerate more slowly and see if the tacho gets to the red line or not. It won't hurt the bike even if it seems painful
Current bikes.
R E GT650
BMW R1200GS
KTM 250 EXC-F
BSA B25SS
Learn to spell! There's a big difference between knowing your shit and knowing you're shit.
NVDucati
  • USA 2020 INT
Reply #21 on: November 24, 2021, 07:40:04 pm
+1 and for fun aim a dashcam at it.
Member: AMA
lucky phil
Reply #22 on: November 24, 2021, 07:42:05 pm
I mentioned this as the probable reason in the second post.
Ciao
Ducati1198
Guzzi V11 Sport/Daytona
GSXR1000
Ducati 1000DS Supersport
RE Interceptor
whippers
Reply #23 on: November 25, 2021, 06:39:36 am
Ciao
Good for you
whippers
Reply #24 on: November 27, 2021, 04:36:30 am
So for interest only I tried slowly accepting in first gear yesterday and can confirm the ignition cutout comes at the same point in all gears. It just appears to be earlier in first because the needle damping stops the needle keeping up with the rate of change of revs.
By the way if you are bouncing this thing off the rev limiter you are riding it wrong
