Royal Enfield Motorcycles => Bullet Electra & AVL => Topic started by: ciderbruce on July 24, 2013, 06:16:37 am
Help: I stored my 2010 Bullet for 6 months. I didn't remove battery or trickle charge. I know, I know. I get nothing when I turn key now. Charged battery - still nothing. Checked 3 fuses and all seem ok. What am I missing?
you might start checking for minor corrosion at battery terminals and go from there. and as you go, maybe apply light dialectric grease to all connections you check. arrgghh...electrical gremlins are heartless.
good luck!
Check your battery again. Make certain it is good, or able to take a charge. They do go bad sitting.
Next like above, check battery connections. Then check the battery ground at the frame, might be corroded there too.
If you stored outside, you might to look into other wire corrosion problems.
Once certain all that is fine, and if it still does not crank,....can you kick start?
Thank you for the replies. After much unsuccessful fussing with the battery I hauled it to the shop. Needed a new ignition switch. Now I have a new key to start the bike but still need the old key to lock and open compartments. Oh well, at least I'm riding again.
I've had some luck with taking saddlebag locks to my local locksmith and having them rekeyed to match the ignition. I hated having 4 different keys for one bike. I had to break out the phone book (remember those?) to find my local guy as many have no online presence.
