I've taken the cam cover off my Interceptor have it powder coated. While it was off, I thought I'd check the valve clearances.
The bike has only done 100 miles since its first service, but I thought I may as well do the check anyway.
In his posting on July 10th last year, twocoolgliders stated that no special tools are required to do the check.
The manual says that after aligning the 'L' mark on the end of the camshaft with the cylinder head, (i.e. when the LH piston is at TDC) a special tool (Part No. ST30260/a) is required which locates in a slot in the camshaft on the RH side and rests on the cylinder head. The diagram shows the tool in place which requires removal of the top of the camshaft bearing housing.
Can anybody explain what this special tool does? If the piston is at TDC on the compression stroke, what else do you need to do before checking the clearances?
I haven't made any adjustment yet, until I hear from the experts out there, but I've done the job many times on my Guzzi V7 with no problems.
Also, the owner manual states that valve clearance is mandatory at every 12 months even if the vehicle has not covered the specified kms. What is the logic behind that?
