Dorthy Parker's quip "You can lead a horticulture but you can't make her think" is apposite. As has been painstakingly explained to you, slide carbs have several fuel circuits controlled by jets and needles etc that each control to a varying degree a particular part of the throttle opening. Folks have helpfully pointed towards texts for your delectation and understanding [which you haven't taken on board]. Thus your engine can be rich at idle, lean just as you open the throttle and rich and lean all the way to a fully open throttle, or any combination thereof. In your case, as has been carefully pointed out, your carb's main jet is far smaller than advised, not a bit smaller, much much smaller. Thus when you open the throttle fully [and before you misunderstand further this has little to do with engine revs] you will have a very weak mixture that will in a short time overheat the piston.
Peering at the plug is not going to help as you neither understand the basics nor how to do plug chops. It would tell ace.cafe a lot, and me a bit, but not you.
I'm not really sure why I'm bothering as it's akin to explaining what colour is to someone who only sees in monochrome. However, as you yourself have said, this thread might come in handy for someone with the wit to benefit.
