If your gearbox is running 90 weight gear oil (some older ones just have grease in there), drain the stuff into a clean container, strain it into a jar through a coffee filter or paper towel, toss a small brush into the jar, and you can later use it to lube your drive chain. A quick slop of the brush over the easy-to-reach lower run of the chain after every ride with a an old cookie sheet or something underneath to catch any drippage, and your chain and sprockets will thank you with far extended service lifespans.
When it's time to refill the gearbox, you might be well advised to find some straight GL-4 rated gear oil. Avoid anything that even mentions "GL-5", since some anti-impact additives used in some formulations of those "GL-2 through GL-5" types can be very harmful to brass or copper bits. If you have trouble finding straight GL-4 in the Automotive section, try the Boating one, as it's often used for outboards and outdrives.
Happy Hunting!
