Royal Enfield Motorcycles => Bullet with the UCE engine => Topic started by: MrMike on April 29, 2013, 02:18:53 am
Title: Ignition Key
Post by: MrMike on April 29, 2013, 02:18:53 am
Need help getting an ignition key.
When I bought my G5 the owner only had one key.  Have been trying to get a duplicate for a couple of weeks.  None of the big box stores have a blank to fit.  Went to a locksmith and he did not want to deal with it.  Went to biggest cycle dealer in the area and he offered to give me a blank I could take to a locksmith.  Then I told him "Royal Enfield" and he said he could not help.  Where do I find a key or a blank?  Tried to contact NField Gear with no luck yet.  Wainting for response.  Any ideas?  Getting old and absent minded.  If I lose this one, I'm sunk.   :(
Title: Re: Ignition Key
Post by: JVS on April 29, 2013, 02:23:11 am
http://www.youtube.com/watch?v=6-i2Qx67O5E
Singhg5 mentions 'A small town locksmith used a Curtis B56 blank key, meant for GM cars, was used to make RE key. It works well for all locks.'
Post by: gremlin on April 29, 2013, 03:24:58 am
your dealer ?
Post by: Joel-in-dallas on April 29, 2013, 03:37:39 am
The nfield store has key blanks as well. With the blank anybody should be able to make it key for you.
http://nfieldgear.com/enfield-store/key-blank.html
Post by: Ice on April 29, 2013, 06:29:11 am
 Nfieldgear a.k.a. the store has genuine R.E. key blanks in stock, give them a call.
Post by: MrMike on April 29, 2013, 12:56:47 pm
Got it second hand. Closest dealer is about 500 miles. Sent email to nfield store.  Will call them today.
Thanks all for responding.
Post by: barenekd on April 29, 2013, 07:42:30 pm
The 24R or 24S blank from Home Depot will work with a bit of work. It's a Ford key. It's thicker and longer than the stock one. The length isn't a problem, but they need to be thinned down a touch. I sanded mine on a belt sander and they worked perfectly. Jack said he got some Yamaha blanks that worked. I think he said he got them from Wally World, oops, WalMart, but you might also try a Yamaha shop and see what they have. The problem with the bike blanks at the shops is they usually want about $10.00 for a blank. That includes NFG. My dealer tried for months to get a blank from them and never did get one. Or he got some that didn't fit a G5. My Home Depot versions cost me about $2.50 cut!
Post by: gremlin on April 29, 2013, 08:43:32 pm
if Nfield fails, I know they are listed on eBay.
Post by: MrMike on May 02, 2013, 03:42:33 am
Just to let folks know.  NField gear has the blanks on back order.  Should get it in three weeks, more or less, at a cost of $11.95 plus shipping.  Rep at NField was very helpful.  Said he can't swear to it but a blank for a pre 1979 Ford truck should work.  I ordered the blank anyway.....  :-\
Post by: barenekd on May 02, 2013, 07:33:25 pm
The one I used is the same as my '96 Ford truck.
I ordered a key through my dealer a couple of years ago. I tried to go through NFG myself, too. My dealer finally got some in. They were for a C5. They won't fit a G5. AFAIK, he's never gotten a G5 one in.
Post by: Jack Leis on May 02, 2013, 09:42:38 pm
I had a Yamaha blank cut to match my G5 key. No filing, just put the new key in and rode away.
Post by: MrMike on May 17, 2013, 04:03:03 am
Jack
Thanks for the tip.  I'm going back the Yamaha dealer to see what we can do.
Mike
Post by: jkrobin on May 29, 2014, 03:50:07 pm
I took my keyblank (from NFG) and my one good existing key to Lowe's a week ago to get a copy made, but their key cutting machine wouldn't do it -- something about the length of the key or something similar. Any suggestions on where to get the key cut/copied?
Thanks!
Post by: boggy on May 29, 2014, 04:25:42 pm
I had a small moto shop make me one, but not from a RE blank.  They just found one that fit and actually had to do a bit of filing to get one edge right but they did it.  Try a small motorcycle shop if there is one around you.
Post by: jkrobin on May 29, 2014, 04:48:51 pm
Thanks, boggy. I'll try that.
Post by: Gesewa on May 29, 2014, 05:28:48 pm
I went to my local locksmith and had the Curtis B56 cut to my key.  A little longer but it did also work for me.  $4 out the door.
Post by: NorthernMonkey on May 29, 2014, 05:54:33 pm
hitchcocks in the UK stock genuine blanks
Post by: Ducati Scotty on May 29, 2014, 09:17:10 pm
I just went to a good local locksmith.  He had the blank, said it's used for several different bikes.  Big box will never have it.  Seek out a local cycle shop or good independent locksmith.
