Today I inadvertently "trail rode" my painfully stock I.B. down a Forest Service jeep trail parallel to a powerline access rode. The (up to then pleasant) FS road made an abrupt downhill left hander into a 45 degree talcum silt rutted descent. Too late to stop, I rode it down about 30 feet before the front wheel shod with a K70 at about 30 PSI washed out. Laying under the bike in a puddle of dust ( it's California...), I assessed. #1 - Shut off the engine. #2 - get left leg free, as fuel from the tank cap was dripping on me. #3 - stand the whole sorry mess up in the middle of the hillside, find neutral, horse it around until it was pointed somewhat down hill, find neutral, restart motor, cross fingers.
Two unsuccessful attempts to climb back up this silty dropoff later, I reassessed. The parallel Powerline road was NOT covered with power-sucking silt, just helmet sized rocks. I traversed the burned-over 30 yards across to it on the flattest route I could see. From another flat spot on the power line road I attempted a climb. Not enough motor - feels like second gear? Nope, I was in first. Back down. Attempt #2 saw a faster start, as I knew this was going to be all about momentum. Up we go, the Duro HF308 hooking up well on the hard dirt, steering around the boulders, standing up on the too-forward pegs - 1/2 way, still good - 3/4 upslope, the motor is grunting but still pulling - YES! The top of the hill presents itself. A reprieve for the Geez!
The moral of this story is that I see more clearly why the big twins evaporated from desert racing. The courses got more "technical", it became just too rough for that equipment to successfully compete. Two strokes, with their light weight and superior horsepower and more user-friendly gearboxes put the spike in the coffin. The Bullet needs significantly lower gearing, and obviously more appropriate tires, to function as a trail bike. Picking up a near 400 pound machine on a loose hillside and not being able to start it in gear gives the competition riding a 250 pound machine a real advantage. To its credit, that venerable ancient tractor motor did drag my carcass up a near 25 degree slope and blithely steer around the boulders while doing it. A 50T rear sprocket and at least some 4" wide trials tires would have helped considerably. I'll henceforth stick to tarmac & flat hard dirt on the Red bike, and wait on the fire roads until the Green machine is properly kitted! - ACR -
