Author Topic: What did you do to your RE Continental GT today?  (Read 391163 times)
0 Members and 3 Guests are viewing this topic.
Arschloch
  • ...all is lost
Reply #1335 on: June 18, 2021, 06:25:46 pm
I don't know what the max oil pressure is in the uce however the super duper big block marine application expensive oil pressure switch that I installed with 50 years market history and experience sized working and started leaking oil even though it's rubber mounted, hose connected and doesn't see the engine vibs neither temps. ::)
Taurim
Reply #1336 on: June 18, 2021, 06:56:27 pm
Interesting ! Where did you plug the hose bringing pressured oil to the switch ?
What did you do with the information ? lighting a red bulb or shutting down the ignition ?
Arschloch
  • ...all is lost
Reply #1337 on: June 18, 2021, 07:42:34 pm
The oil line is connected to the oil filter housing and the bulb to the kl15 that comes on when the ignition key is turned on.
Going to put in a switch with lesser market history.
« Last Edit: June 18, 2021, 07:45:08 pm by derottone »
Taurim
Reply #1338 on: June 18, 2021, 08:01:45 pm
Maybe you could install a passive oil pressure gauge ?
I have one like that in my Lotus.
There is no safety switch but at least you can check what your oil pump is doing.
KC1961
Reply #1339 on: June 25, 2021, 09:32:20 pm
Not today, a week or so ago. I had to replace the oe front pads (11400 miles). Like the other Brembo braked bikes I've owned (Ducati, KTM, CCM), EBC pads work so much better than Brembo's own. Only downside is that the damper-rod type (pogo stick) forks are now in more need of cartridge emulators than before. This will be attended to soon. Has anyone used emulators, any opinions?
gizzo
  • purple people
Reply #1340 on: June 26, 2021, 01:18:31 am
Agree, the EBC pads turn it into a good brake. I think it took me 4 sets of the other pads to work that out...
Have you seen all the guff about fork mods on the 650 CGT/INT forum? I thinks it's pretty much the same fork. I'm always intending to do the YSS emulator mod but never get around to it. I'll replace the springs at the same time i guess. The stock ones are too easy to use all the travel on. Same for the rears. Some of the 650 guys say the Hagons from H are a good and economical replacement.
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
gizzo
  • purple people
Reply #1341 on: July 12, 2021, 03:41:50 am
50,000km :)
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
oldphart
Reply #1342 on: July 12, 2021, 08:00:03 am
50,000km :)
And all on only 2/3rds of a tank of fuel  8)
Grandpa Slow
2021 Classic 500
Arschloch
  • ...all is lost
Reply #1343 on: July 13, 2021, 02:30:31 pm
50,000km :)
Very cool.  8) ...my tach doesn't seem to move much since corona at all.  :(
gizzo
  • purple people
Reply #1344 on: July 13, 2021, 02:37:21 pm
Continental GT
Pantah
DR250
DRZ400SM
C90
GSX250E
Guaire
Reply #1345 on: July 13, 2021, 04:11:58 pm
50,000km :)
That's a lot of kilometers!
ACE Motors - sales & administration
Dinasaur
  • Fitter machinest RE Harley Ducati
Reply #1346 on: July 26, 2021, 02:05:12 pm
Gday all fitted a new rear tire today went from a 130 to a 140 sport demon suits the bike well and fits with no problems and looks good also thought  I show you a few mods to improve function and looks fitted rod end bearings to that sloppy gear shifter linkage grind off welds punch out old ball joints for 6mm stainless screw and nylok nut and on goes the left and right threaded bearings also deleted the heal guard and bracket drilled lightning holes in the levers added grease nipples and painted also got rid of the duel horns and placed single horn on convenient bracket behind cylinder here's some pics oh I also cut down the right side heel guard
« Last Edit: July 26, 2021, 02:27:00 pm by Dinasaur »
GT 535 Harley Ducati
KC1961
Reply #1347 on: July 28, 2021, 08:26:43 pm
I previously had an AEW silencer on my 535. Sold it for the exact same reason.
It's taken longer than it should've but I've fitted a "catalytic converter" style baffle to my AEW silencer. Sounds lovely, still has that deep tone and riding through built up areas at 2 - 2 1/2 thou' on a transient throttle it doesn't sound offensive at all. Still a bit louder than I'd prefer when the revs are up and the engines pulling but nowhere near as loud as "sans" baffle. Quite happy now.
Taurim
Reply #1348 on: July 28, 2021, 08:33:53 pm
How did you adapt it to the AEW silencer ?
KC1961
Reply #1349 on: July 28, 2021, 09:00:28 pm
I removed the AEW end cap and tapped the baffle in large end first until the smaller end was flush with the AEW baffle then I run a ring of silicon sealer around between the new baffle and the AEW baffle before refitting the end cap. Now that I know I'm happy with this baffle I will see if I can come up with a better arrangement.
