Thank you, the front lil marker lights are just wired as they should be. Thing is once I identified right and left turn signal leads wired lights into em things went south. Right side blinkers were nice an bright, left were not, then the left quit all together, then the right, then the ammeter quit an i lost spark. I removed everything turn signal, checking wiggling every connection in the headlight, I then checked fuse, good, battery great, the lead from the points to coil good... still no spark, still a dead ammeter.
