Hello, Hoping I get get some answers here so I dont have to spend hundreds with a garage. I have a 2016 C5 which has been misfiring and running rough. I have adjusted the TPS voltage but the MIL light shows the following errors. Could I get some guidance on what needs doing or could this be a battery issue?
Adjusted the TPS voltage as best as I can get it. Took the bike for a spin and it has improved. No misfires. However the MIL light is now continuously light and the power delivery seems a bit rough through the higher gears.. When I check the error codes as per the manual I got the following:
Short 6 -TPMS sensor circuit malfunction.
Short 9 - Manifold Absolute Pressure (MAP) circuit
malfunctioning.
Long 6 Short 6 - Crankshaft position circuit malfunctioning
Im a bit surprised by the last one though I now have to address all the issues.
