The whole case gets bigger, taking the hole along with it. I freeze the bearings also(if some is good, more is better, right?), but I've lived mostly in dry places. Lots of condensation on a frozen bearing at 80% humidity, not so much at 4%.
After the bearing is seated, a little more heat & WD40 have always seemed to make things acceptably dry again.
IF a guy had an inside mike, a non-contact thermometer & propane torch it would make an interesting YouTube Vid to track hole size as you heat the case, hint hint...
Always good to
prove what you
think you know in my experience.
