Author Topic: GT 650 Speedometer and Tachometer Wires  (Read 1598 times)
jackgilly
on: August 11, 2024, 11:01:20 am
I have a 2021 GT 650 and I’m having problems reconnecting the original speedometer/tacho unit wires to the main harness… originally it was connected inside the headlight housing to the main harness by two connector plugs from the speedometer/tacho unit  but I cut these plugs off a while ago to change the speedometer to aftermarket for track days but now I want to change back to original unit . Is it possible for someone to send me a close up picture me of the original speedo connector plugs that are connected to the main harness so I can see what wire colours go where in each side of the connectors  ?
Thanks
Jack
SteveThackery
  • Inveterate tinkerer
Reply #1 on: August 11, 2024, 02:40:02 pm
Wrong forum - this is an archive of technical tips. If you post this in the 650 Interceptor forum (nearer the top of the page) you will get plenty of good advice.
Meteor 350
Previous:
'14 B5
jackgilly
Reply #2 on: August 11, 2024, 02:42:30 pm
Thanks for your help will do 😎
