Author Topic: Super Meteor Exhaust not in line  (Read 2092 times)
Crepec
on: May 14, 2024, 05:56:52 pm
Hello,
I'm a proud owner of an super meteor 650 and i recognized just an problem at the weekend.
When I get left corners a bit to hard everything is fine -> the footpegs are the first thing that touchs the ground.
But on the right side it is the muffler :'( . The ground was flat at the street and the bike never fellt over or anything. If you look at it from behind sb could assume that the rigth exhaust is a bit further away than the left one but iam not shure i  add an Image
 I just checked the holding points but there is nothing I found that I can adjust - like not even a bit...
Is there sb have comparable problems, hints or any tips?
I don't realy like to change the muffler ... especialy not to have more ground space.
Beside Thank you and Regards
zimmemr
Reply #1 on: May 16, 2024, 03:59:38 pm
I'd go look at another one, it may be common to all of them, if that's the case you're probably best-off learning to live with it. If it isn't let your dealer know and see what he suggests.
