Author Topic: Help/Advice on Brake Pads for GT 650...  (Read 1753 times)
JohnLA
on: November 18, 2023, 09:15:17 am
Hi All-
Can somebody advise me on the following? Thanks so very much for any help/advice/suggestions...
1. What might be the "best" or "better" brake pads for my GT 650 from the link below. Non-sintered, Semi-sintered, fully sintered?
2. Would it be much of an upgrade to also get the front and rear EBC discs also listed in the same link?
Link is here: https://ebcbrakesdirect.com/motorcycle/royal-enfield/continental-gt/25038037?_page=1
Thanks again for any advice!
Cheers.
John down in Greece
Deathwish
  • Deathwish
Reply #1 on: November 18, 2023, 03:36:10 pm
I believe EBC HH sintered pads on the stock rotors are a vast improvement.
JohnLA
Reply #2 on: November 18, 2023, 05:11:59 pm
Thanks for your reply Deathwish. I appreciate it. Yes, I remember reading last year on here about sintered pads being much better. Maybe why I am not getting more replies.  ;D Guess I am just looking for a little "hand-holding" before I make the purchase. I am curious about the EBC discs too, and if anybody here has installed them on our bikes and what they thought of them.
Thanks again for taking the time to respond to my post.
Cheers.
John down in Greece.
« Last Edit: November 18, 2023, 05:14:46 pm by JohnLA »
Tuh
Reply #3 on: November 18, 2023, 06:16:36 pm
+1!
JessHerbst
Reply #4 on: November 18, 2023, 06:22:33 pm
+1
2022 Continental GT650
Quest
Reply #5 on: November 18, 2023, 06:34:35 pm
There is also the Brembo Street/Trackday front pads.
These came to our attention via @Couchie
Brembo part no. 07BB03SA
https://www.carpimoto.com/en-US/
Don't know about current availability but worth the effort.
Got curious and checked. Yup, in stock.
« Last Edit: November 18, 2023, 06:37:31 pm by Quest »
NJ Mike
Reply #6 on: November 18, 2023, 07:10:08 pm
EBC HH is a solid upgrade.
Been riding since 1980. Live in Bloomfield, NJ.
Current Ride: 2019 RE Conti GT 650
Past Rides: 2002 SV 650, 2001 Moto-Guzzi V11 Sport, 1985 BMW K75, 1992 Honda 750 Nighthawk, 1982 Yamaha Vision, 1981 Kawasaki GPZ 550, 1978 Honda 750F, 1980 Honda 650
Suncoast
Reply #7 on: November 18, 2023, 07:27:25 pm
I went with EBC Sintered up front and Semi Sintered in the rear because my foot in a boot isn't as sensitive as my hand for braking. Seems to work well for me!
2021 Royal Enfield Continental GT
2003 Honda VFR 800
Gone but not forgotten,2016 GSXS1000F, 2008 Suzuki B-King, 2014 Triumph Street Triple RX, 2011 GSXR750,2008 Moto Guzzi Breva 1100, 1996 Kawasaki Vulcan, 1983 Suzuki Katana 750,
fireypete
Reply #8 on: November 18, 2023, 08:41:19 pm
I'm running Brembo sintered up front, noticed an improvement. Worth the investment. Whether it's Brembo or EBC. As a side note, running in the brembos made the disc look quite dirty. Don't clean it off like me😕. It's part of the resins and helps the disc and pad bed in. It will wear off in time.
I have standard discs and they are holding up fine.
TSTM
Reply #9 on: November 18, 2023, 10:52:11 pm
The standard front disc on my '22 Continental says Brembo (not Bybre), not sure about the rear, have to check.
'22 Continental GT 650
previous bikes
Yamaha XS650
Honda Shadow VLC
Moto Guzzi California 1100
Maico 490 dirtbike
JohnLA
Reply #10 on: November 19, 2023, 08:44:52 am
Thanks so very much everybody. Really appreciate all the replies. Will be getting the sintered EBC HH pads for the front and back. Will wait on the new rotors for now.
Cheers.
NJ Mike
Reply #11 on: November 19, 2023, 01:44:22 pm
Cheers.
The stock rotors are fine. When mine wear out I’ll see what’s available, but no reason to swap them out otherwise.
JohnLA
Reply #12 on: November 19, 2023, 03:46:30 pm
Thanks for this NJ Mike. I will follow your advice.
Hog Head
Reply #13 on: November 20, 2023, 02:49:15 am
If you want significant better braking, this 4 pot Brembo brake mod is significantly more braking torque, but significantly more money
https://rstech.my-online.store/product/royal-enfield-brake-upgrade
EBC-HH pads are an improvement, but do not expect a night and day change in performance.  Better with a Brembo RCS-15 master cylinder, but brake torque is limited by the stock rotor diameter and calliper piston area.
Higher coefficient pads and a 15mm radial master cylinder is a good middle ground upgrade at a reasonable cost
Ducati Supersport S
Harley XR1200
Triumph T-120 Bonnie (Hinkley)
RE 650 Interceptor
Harley XL1200R
JohnLA
Reply #14 on: November 20, 2023, 12:22:08 pm
Thanks for this Hog Head. Very nice!
